What's changed in Amendment 4:2026?
We co-publish BS 7671 with the British Standards Institution (BSI) and lead the UK’s national Wiring Regulations committee, JPEL/64, ensuring the standard reflects both international developments and UK-specific needs.
Key areas of change include:
- A new chapter on Stationary Secondary Batteries, where the purpose is for electrical storage and supply of electrical installations.
- A new section on Functional earthing and functional equipotential bonding for information and communication technology (ICT) equipment and systems.
- A new section on Power over Ethernet (PoE).
- A major revision of Section 710 Medical Locations and the inclusion of a schedule of test results for recording the resistance of supplementary protective equipotential bonding conductors.
The transition period for BS 7671:2018+A2:2022 (Amendment 2) ended on 15 October 2026. As a result, Amendment 2 is now obsolete and should no longer be referenced for new electrical installation work, project specifications, certification or compliance purposes.
To ensure compliance with the latest requirements of the IET Wiring Regulations, electrical professionals should use BS 7671:2018+A4:2026 (Amendment 4), which is now the current edition of the national standard for electrical installations in the UK.
Buy your copy of Amendment 4:2026
Protect yourself from dangerous fake copies of BS 7671 and other IET publications by buying your copy from the IET bookshop or one of our trusted resellers.
Alternatively, our Digital Wiring Regulations (DWR) subscription packages provide instant online access to BS 7671 and a wide range of IET guidance.
How updates to BS 7671 are published
Editorial corrections to IET publications are made quarterly. Urgent technical changes are published as and when required.
Check back on this page regularly or subscribe to Wiring Matters for updates.
Note on copyright
No further electronic copying of downloaded updates is permitted without written permission. You may create a web link to this page, from which others can select and download documents. Direct links to documents are not permitted.
Errata and corrections for current publications
Amendment 3:2024 to BS 7671:2018 IET Wiring Regulations (the Brown Book)
Amendment 3:2024, the free-to-download PDF ‘bolt-on’ to the brown book published is now available for free below.
You will now need both the brown book and the free PDF to be up-to-date.
The Brown book, Amendment 2:2022 and the PDF ‘bolt-on’ will be valid until 15 October 2026.
Corrigendum (May 2023) to BS 7671:2018+A2:2022
The Corrigendum (May 2023) to BS 7671:2018+A2:2022 is available to download below.
Previous edition corrections
The following corrections relate to earlier amendments or editions and remain available for reference:
